willness33
Here for the memes
- May 3, 2005
- Alexis,NC
Alright, this is a stumper. I installed a new programmable t-stat last night. It was wired correctly, but the furnace was acting odd on shutdown at the end of the heat cycle. Then it started blowing fuses. So what did I do? I put in a bigger fuse. Yeah, I know. So, because of that I blew out the low voltage transformer. New one is in and the old thermostat is back on. The furnace heats fine, but still with the odd shutdown. It keeps kicking that blower fan back on a few times after the heat exchanger is sufficiently cooled. It's throwing a code for me as well. It's saying "limit circuit open or external load on 'W'". Ok, I checked the limit switches while it was doing it odd thing while the code was flashing. THis is on the cooldown cycle. All of the switches had good continuity. That means they are not open and that's not the problem. So, what I checked next was the voltages on the different leads, while the furnace is not running. 27 on red, 0 on green or yellow, and here's the odd part, 5V on the white wire. I thought the white wire was supposed to show 0V to ground when the furnace isn't running. Someone please confirm or deny my knowledge and set me straight. IMO, the 5V on the white would possibly be the external load on the W? Any info would be very helpful as it's going to be another cold night tonight!
