First off I know it's kinda fighting a losing battle w/ large bias tire...but i'm soooo close to actually having a pretty good riding rig....
Ok, so I got a set of used bias ply tsl's 39.5x15. They are on a new set of 17x9 steelies. Unbalanced all the tires regards of front back left or right all drove like crap. After confirming all steering parts, TRES and alignment was good...I figured I'd try the airsoft pellets to try to balance the bias tsl.
I started out with 12oz in each tire...that helped but didn't fix all the wobble. After about 2lbs of bb's in each tire I'm able to get 3 out of the 4 tires to ride really good up to about 60-65. I'm cool with that speed.
The problem is one tire regardless of it's on the front or back likes to wobble and hop. I added a total of 44oz or 2.5lbs of pellets to this tire to try to balance it out more, but no change. So I popped the beads and rotated the tire 180degrees on the wheel and now my left and right wobble is pretty much gone (that one tire looked like it was having serious death wobble) where as the other side was tracking fine.
So I now have the wobble gone, but the tire looks like it has a serious hop up and down issue. I've been marking the tire/wheel so I can continue to rotate 1/4 of a turn to find a good spot for the combo to be as balanced as it can be....to no luck (the wobble comes back when I rotated it 1/4 turn).
Just wondering if there are anymore ideas...after about 12 times of popping the bead and adding bb's or rotating the rim...it's get a little old I hardly know squat about tires balancing outside of what I've already done....and just wondering if someone could point me in the right direction incase i'm missing something about what to do to get a tire to keep from going up and down???
