Im working on setting up a HP D44 using a homemade case spreader. i've read through billavista's gear article half dozen times now and cant find anywhere that he mentions loosening the spreader once the carrier is in place to get a true indication on the gear marking compound. using it last night, i checked the pattern in 3 places with the spreader on tight, then checked the pattern again in 2 other places with the spreader loose and it appeared that the pattern moved towards the Toe. does that seem right?
also, i seem to be getting a much clearer pattern on the Drive side (reverse cut gears). there is a pattern on the Coast side but its not as distinct. any thoughts?
