Exactly. If you hit something hard enough to create the same force that a 30 mph head on causes, You're gonna want the airbags to go off to help protect your ars.Most airbags systems use and inertia switch basically a ball mounted on a spring Chrysler vehicles have them built into the airbag control module it is not how fast you hit something it is how hard you hit it that blows the bag(s).
An airbag can blow at 0-5 mph just as well as 35 mph, inertia and deceleration rate are what trigger the bag. The last airbag class I took was 2 days long there is alot to them, when off road to prevent a very expensive and un-necessary repair pull the fuses.Exactly. If you hit something hard enough to create the same force that a 30 mph head on causes, You're gonna want the airbags to go off to help protect your ars.
Sorry but I don't think you have enough inertia at 5 mph to deploy the airbags. If that were to happen the 5mph bummpers would be a moot point. (As in the person from NYC who parks by braille at 5 mph would cause $3k worth of damage to their vehicle by deploying the airbags and it really wouldn't matter that the bumpers weren't damaged. The last airbag class I took was 3 days and it involved fiber optics for information and crash data transfer. Believe me, I know there is a lot to an airbag system. I've seen cars that were totaled by a side impact and only the side that was impacted had the airbag go off. Neither one of the fronts went off. BMW sent an engineer out to see why they didn't. The conclusion, they weren't supposed to go off. There wasn't enough forward force to deploy the front bags.An airbag can blow at 0-5 mph just as well as 35 mph, inertia and deceleration rate are what trigger the bag. The last airbag class I took was 2 days long there is alot to them, when off road to prevent a very expensive and un-necessary repair pull the fuses.
Yeah, that has me thinking about my airbags now. That is a good video...shows you the speed and force of the airbags.search youtube for " ZJ deploys airbags "
a good reason to pull the fuse...
Looke dlike the jeep only hit below the bumper too. No head on collision needed.
Here it is
http://www.youtube.com/watch?v=cs44P5nNrDs
Again the airbags used in Jeeps are inertia sensitive, there is no front impact sensor on that Grand Cherokee only sensor to deploy the bag is in the control module under the console, same for Wranglers(TJ) and 97-98 XJ's had a recall to re locate the airbag control module to under the console it was under the drivers seat from the factory but they didn't think people would put stuff on the floor that would roll under the seat and deploy the bag.Yeah, that has me thinking about my airbags now. That is a good video...shows you the speed and force of the airbags.
Here it is
I have taken classes on this as well and just pulling the fuse will not completely prevent an airbag from deploying. Any sort of short could set it off. So just leave them alone and you should be fine.
There is no way a short can set off a airbag.
That is not true just because the airbag light is on the system can still work or at least Chrysler system do, the only way to keep the system off is to pull both fuses. A short to 12v on the squib circuit can blow the bag.also on all air bag systems there is a fault check by the air bag computer. if there is any thing wrong with th system then they will not deply. there is air bag light just like a check engine light that will notify you of that
