- Mar 17, 2005
- N. N. Raleigh, NC
With the new sleeper cab I wanted to explore the possibility of reusing the built in A/C unit. Inside the cab is a complete A/C heater setup w/ blower motor and small distribution system. The heat loop would be easy to use with small inline coolant heater/pump unit..
It has a an evaporator and i think an expansion valve?
1) What would I need to make this work again ? I'm assuming because it was in a 97 truck it is R134, i do have access to a deep vacuum pump and gauge/manifold set so Id have no problem assembling some parts..
2) another option i can think of is using a regular window unit and mounting it in a location where the controls can be reached AND the hot exhaust easily vented out as well as cool (er) outside air drawn in to cool it..
3) ive seen the portable style AC units but i havn't seen any under 10k and not super tall.. ??
Anyway here's what im working with...
