Something to think about while looking for some help. Got it off a HVAC forum
Compressor pull high amps
Excessive suction pressure beyond the limits of the compressors ability to run. Check the performance charts of the compressor for the maximum suction pressure. The use of a Crankcase Pressure Regulator (CPR) or pressure limited TXV (MOP) may be required.
Excessive system load.
Improperly wired (very common mistake).
Defective run or start capacitor.
High or low voltage.
Excessive discharge pressure.
Incorrect refrigerant.
Tight bearings or mechanical damage in the compressor.
Burned contacts.
Supply wire too small of gauge.
Voltage out of balance on 3 phase systems.
Sticking start relay.
