Any Walker mower guys on here
Ibayne
Fletcher
Ok got a 26hp EFI and it’s skipping sputtering to the point it almost useless. So replaced plugs, fuel filter, fuel pump, ran a can of seafoam thru an still skipping an sputtering... not as bad but still doing it... any ideas
Hoping it’s nothing that serious... hoping O2 sensor or something else. Been reading they had some ground wire issues an to trace them all to see if that’s the problem
Coil would be my first guess.
Fuel pumps are pretty notorious for going south on those things. I see you replaced the fuel pump, so that kind of nulls that point. Did you use the correct fuel filter? I'd need more info from the machine, i.e. model and serial, to be able to help you further.
Thanks for the help guys...started unpluggin stuff today o2 sensor, tps, then went to coils...one coil it would run on the other it wouldn’t got to looking ground wire had come loose on that coil... all that an a dang 5/16 wrench fixed it... thanks again for the help gents
