I don't have one, but I have found several evap system leaks by buying a cheap non vented gas cap, drilling a hole through it, and sealing a shrader valve in the cap. Then put the cap on, lower your regulator way down, and put no more than 5psi in the tank. You can then listen for the air escape and track it down. (This also works awesome if you have a duramax or other diesel without a lift pump to prime the fuel system, works 10x faster than hand pumping, that's what I originally built the cap for) I've used that method to find two evap leaks on my wife's Infiniti, and one on a family member's Honda. There was one other I was able to hear escaping but never found the leak so they had to take it to a shop with a smoke machine, wound up being the gasket around the sender.Be sure not to put more than 2-5psi in, or you may risk creating another leak.
I have heard of others using my method, but using a party fog/smoke machine and pumping the smoke into the tank, then pressurizing the system to push the smoke out.
