Tacoma747
- Mar 20, 2005
- Winston-Salem
Planning on making a water stove to keep from using the fireplaces (with inserts) to heat my house. The upstairs insert works great, but the living room stays WAY too hot, the air just doesn't circulate very well. I'll probably end up selling the upstairs insert (large Buck) and the smaller one in the basement (not sure brand).
Has anyone ever dealt with the pluming/wiring etc. with an outdoor water stove?
If you don't know what it is, you heat water with a large woodstove, pump the water through a radiator in the ductwork in the house and use the original furnace blower.
I will be getting what was a sterilizer out of a hospital, firbox will be pretty large, and the construction is perfect for a water stove. Figuring out what type pump to use and all the little stuff is the tricky part, just wondering if anyone has done it before.
Thanks
Thanks
