jeep9mm said:
when was it that small? My 04 is 19 gallons from the factory and when im really really low i get 17-18 in there
'99 was the last year of the 15-gallon standard, 19-gallon optional tank...
Mangler may have the story on the YJ...but here's what they did on the TJ...
made a single sized (external dimensions) fuel tank...
had a vent tube inside the tank at a certain length that allowed you to only get 15 gallons in it...
for ~$200, you could "upgrade" and you'd get the exact same tank...except the vent tube was shorter, which allowed you to be able to get 19 gallons in it...
if you cut the tube flush with the tank, you can easily get 19+ gallons in...
the pump was the same size...just the different sending units so the guage was rights...
the entire reason I did it on my '99...was the fuel guage would never go over 3/4 tank...got the part number off the side of the tank, and it was a 15-gallon tank...the build sheet said we had a 19-gallon, but the Jeep has a salvage title...
so, ended up finding it had a replacement 15-gallon tank, but still had the 19-gallon sending unit...so a full 15 gallons only looked like 3/4 tank...
once we cut the vent tube from inside the tank, the guage now shows full...
Greg
