hans747
- Feb 20, 2007
- Asheville, NC
Hey guys,
i have a dehumidifier in my basement that started acting weird the other day. If you unplug it for a while it starts up fine, runs for a while and then shuts off like normal. A little while later it will try to cycle on again, but it shuts down after about 2-3 seconds (kinda like the humistat turned it off). 30 seconds later, it will repeat. It will do that about 5 times and then give up.
This is with an empty tank, the "full" light is not on, and the humistat is turned all the way over to 'dry'.
Any ideas where I should stat looking? If worse comes to worse, can I bypass the humistat and just plug it into a timer?
