At a loss. New crank, new motor...??? What to do.
atblis
SW VA
Alright, some background. 3 out of 6 of the crankshaft flange holes are stripped. I am having doubts about being able to repair them. so... This is all for a 79 CJ5 with a 258.
Here's a link to my previous post about it
http://www.nc4x4.com/forums/showthread.php?t=27441
3 questions/possibilities. Feel free to comment on all.
1) Do you guys think a helicoil or time-sert would work? The flange is only .366" thick, and the holes are perilously close to the edge of the flange. That actually worries me more the than the thickness. I am most curious about the time-serts.
http://www.timesert.com/
I am looking at $100ish for the kit. If putting a new crank in is about the same, I'd rather go that route despite the extra work.
2) Supposing I do decide to put a new crank in the motor, what am I looking at effort/cost wise? I think
a. find a new crank (I've already got a 77 Cj with a 258 for parts)
b. Make sure crank is serviceable (polish/grind if necessary).
c. obtain correct bearings for mains and rods
Would it be better just to rebuild a motor? The engine ran decently except for an odd knock, which I suspect could have been the flywheel/crank issue.
3) New motor. I like the 258, but if I can get my hands on a decent 401... What do I need to swap to a V8. Just motor mounts? Possibly a bigger radiator...?
Better plant a whole fawkin grove of money trees, get a larger wallet, & then start repairing all the stuff you'll break!
Seriously, it shouldn't be hard to find a 258 crank & a set of bearings for under a couple Benjamin's...
You already have the crank, having it checked out, polished and sized for new bearings you'll have maybe $200 tops unless you feel the need to balance it ( I wouldn't)
Replacment is probably the best and most reliabe option.
Helicoils and Timeserts both remove a small amount of material, and with out knowing if damage has been done to the crank thru harmonics of a loose flywheel, it could frag not long after you repair.
If you already have it, use it, you now have a tall doorstop, wheel chock, boat anchor (pick one)
Yeah
I was thinking mailbox. I6 cranks make nice mailboxes.
Yep I pretty much decided to put a new crank in the 258. I was getting 21mpg Hwy with it. I don't think I'd get that with a 401.
I'll start ripping apart the 77 tomorrow. The motor in it ran, and didn't sound bad so hopefully the crank will be decent.
