I'm building a buggy (4.3L, 4L60E or older 700R4 or TH350, 4:1 dana 300).
how many people with buggies or very built crawlers use manual valve body in their automatics? Is it worth the cost/trouble?
for those that do not, do you have a problem with it shifting when you don't want it to?
manual valve bodies also maintain a constant line pressure in the tranny, is this hard on the tranny and the pump?
If currently got the 4L60E that was mated to my motor, but there its no manual valve body for 4L60E if I wanted one, so i'd either have to use an older 700R4 or TH350...
What do you think? Thanks for the advice in advance..
) find was 65-70mph, decelerating, & mistakenly dropped into 1st... it held each gear, downshifting when the next gear wouldn't spin the engine past rod snapping RPM... very controlled QUICK decel!
