Ricky B
Wiiide Open
- Mar 20, 2005
- LKN - Tha Dirty Mo (Mooresville, NC)
ok for those of you who know audio stuff
I have one audiobahn 10" 800watt rms sub right now
- in your opinion whats better 2 10" 800watt rms subs or a single 15" 1300rms sub?
- that being said i'm leaning toward the single 15" 1300rms sub just because of the greater wattage and surface area.
- the single 15" sub has:
#2,600 watts MAX
# 1,300 RMS Output
# 180 oz. Triple-Stacked Magnet
# Multi-Connect Lug-Lock Terminals
# Mounting Depth: 9 5/8”
# Hole Cutout: 13 3/4”
# 15 inches
# Recommended Sealed Box Dimensions: 1.50 - 3 cu. ft.
# Recommended Ported Box Dimensions: 1.6 - 4.0 cu. ft.
# Sensitivity: 94 dB
# Frequency Response: 15-500 Hz
# Dual 4 ohms voice coils
- I have two audiobahn a8000t amps that push 800watts each when you hook em up right (like 1 ohm maybe i dont really understand ohm stuff i just know how to hook one up to my current sub to push the 800watts)
- i know how it works to hook up the a8000t amp to get it to run the 800 watts to my audiobahn aw1006t 10" sub, how would i hook the two a8000t amps to the 15" awes15p sub to get it to run its wattage? Main thing im worried about is just trying to figure out where/how to hook the two amps to the 15" to get it to run at full capacity.
Thanks
#2,600 watts MAX
# 1,300 RMS Output
# 15 inches
Thanks
