84_k5
Member
- Jan 24, 2010
- Spartanburg
its a 84 k5 blazer. the four wheel drive will engage and the driveshaft will spin but the hubs will not lock. this is my first 4x4 so any help would be appreciated.
maybe the spring inside the hub is broken or theer is trash inside where the splines are not allowing it to engage. best thing would be take it apart and check for broken parts
x2...mile marker manual hubs are cheap and will probably suffice for you. warn hubs are good,cost a little more but does the same job...there straight foward and an easy install.
wheres the best place to buy them?how easy would it be to change them over? What all has to be done? and what kind Money am i lookin at spending?
Warn hubs are usually around $100 - $150 for a set and can be found at most major auto parts store I would call them all I have found prices vary alot for the same product.
AS for the install not real familar with k5 but usually it is just remove cap and replace with locking hub. Sounds like with the your axle you'll have to over ride your auto locking hub.
If you're in Spartanburg, SC I've got a set you can have. They were advertised as Warn, but didn't have anything Warn on them when I got them. They are the quarter turn hubs, not the full turning ones. Come over next weekend and I'll teach you how to swap them out....for free. I've taken mine in and out of my K5 several times. Pm me if you're interested. - Stacy
