Chuckman
- Oct 9, 2005
- Huntersville
So Im looking at putting a 44/9 combo in Vortecjeeps TJ. What we are looking at is the pinion offset of the 9" vs the D35. I have swapped enough axles, and have run into bigger problems, but this is not MY rig and I dont want to just do whatever is easiest at the time, and I dont want to move the drivetrain like Ive done before. The main issue is he will be 3" further axle stickout out on one side if we line the yokes up. We will have to go SYE with the lift, so we will be working with a CV rear shaft. This IMO dictates that we line up the rear to avoid vibrations. He will be driving this alot on the road and is putting on good tires so any vibrations will be noticable. So, heres the options as I see it. 1) shorten the long side- but I dont have a jig for rewelding the flange and this sounds tricky 2) center the axle and have it misalinged by 1.5" 3) turn the drivetrain to match the offset angle on the CV- I have done this on mine, but I was dealing with an existing engine swap that made it easier. 4) wheel spacer on one side 5) run it sticking out and deal with it.
What have you guys done that worked? I want it to be right, but you know about Pandoras box...
alright, whatcha got that worked/didnt?
