Not knowing what type terrain you have "down under", best I can do is a generic answer.
The years are about right for a Dana 60 front. You would want to upgrade it though. Minimum, 35 spline outers. IMO go with drive flanges. Reason being when you upgrade to 35 spline, the lock out hubs I have seen don't hold up. Then of course you can keep going also with up grading the inners as well. The Chrom-moly stuff is about as tough as you wanna go, unless you want to drop the big coin and go with a Birfield type axles set up from Bobby Longfield.
The rear is a good choice, but in my opinion I would look for a Dana 70 instead. The 70 is already 35 spline and the housing is the same as a Dana 60. So, no difference in clearance concerns.
An even better choice is the Corp Full Floater 14 bolt. Heavier axles, and you get an extra bearing in the pinion. The down side to going with a 14 bolt is the gearing selections available. You can go as low as 7.17 in a 60 or 70, but only 5.38 in a 14 bolt. But there is a shave kit for the 14 bolt that will give you bunches of clearance.
The T 350 and 400 are great trannys. But consider either a Dana 300 with upgraded output shafts, and a 4:1 gear set. or,.. a 203/205 doubler. Better yet, an Atlas 4 speed.
Hope this helps and don't be a stranger, post up pics and details in the build section!
Welcome to NC4X4 .com!
