flatbedtoy
- May 1, 2008
- Lexington
Can anyone ID this axle? Spring under, full width, 5 lug.
Aren't 8 3/4 Chryslers pull out diff housings like Ford 9" and Toyota's? The car came stock with the 8 3/4" from the factory, but this is something stuck under the car just to get it on the trailer. The spring perches are too wide for the Demons leaf springs.Bet its a chrysler 8.25. Makes sense with the rubber fill plug
Sent from my SPH-D710 using Tapatalk 2
Yep, I have regeared many old Mopar 8 3/4's. Definately a Dana/Spicer rear pictured here. I would say an older J truck 44 rear, except it's spring under...Aren't 8 3/4 Chryslers pull out diff housings like Ford 9" and Toyota's? The car came stock with the 8 3/4" from the factory, but this is something stuck under the car just to get it on the trailer. The spring perches are too wide for the Demons leaf springs.
Yeah I was thinking early 44, doesn' t match most 44' s I've seen, but.....Yep, I have regeared many old Mopar 8 3/4's. Definately a Dana/Spicer rear pictured here. I would say an older J truck 44 rear, except it's spring under...
Looks like an old Dana 44 rear to me.
Good info, you may be right.I think thats a borg warner M78 also. I had a third gen firebird and remember the rear axle looking like this. It had 9 bolts like the one pictured.
http://www.thirdgen.org/techboard/faq-board/239666-everything-i-know-about.html
So you gonna put your buddies demon build on here?? you should lmao
