1stgenxxx Well-Known Member Joined Dec 19, 2005 Location Hudson Apr 16, 2008 #1 I can use Chevy 8 lug outers on my Ford HP 44 correct?
wheelNC94GC Well-Known Member Joined May 19, 2007 Location Chesnee SC Apr 16, 2008 #2 As long as you change everything from the knuckle out. . . . knuckle, spindle, brakes, stub shaft, etc.
Ricky B Wiiide Open Joined Mar 20, 2005 Location LKN - Tha Dirty Mo (Mooresville, NC) Apr 16, 2008 #3 Yea stub shafts are different length
1stgenxxx Well-Known Member Joined Dec 19, 2005 Location Hudson Apr 17, 2008 #4 Thanks for the help. I'm going to need a carrier that accepts 392 and lower gears. Iou can't use a carrier from a standard rotation 44 can I?
paradisePWoffrd Recovering Project Junkie Joined Nov 5, 2005 Location Newton, NC Apr 17, 2008 #5 iirc, d44s use the same carrier whether LP or HP
1stgenxxx Well-Known Member Joined Dec 19, 2005 Location Hudson Apr 18, 2008 #6 Is the 10 bolt carrier the same as the 44?
paradisePWoffrd Recovering Project Junkie Joined Nov 5, 2005 Location Newton, NC Apr 18, 2008 #7 1stgenxxx said: Is the 10 bolt carrier the same as the 44? Click to expand... nope
Cperry Well-Known Member Joined Apr 24, 2005 Location Durham, NC Apr 18, 2008 #8 LP Hp cases are the same, 10 bolt and 44 are not as far as I know and i am 99.9% sure.
BigWheelBob Well-Known Member Joined Mar 31, 2005 Location hubert,n.c. Apr 18, 2008 #9 Not even close.
Metto Well-Known Member Joined Mar 20, 2005 Location Cornelius, NC Apr 18, 2008 #10 jeff i got the carrier you need, pm me
