Axle Opinions Please
Bridgeman
Anson County
What do you guys think about putting a GM 10 bolt and GM 12 bolt from a 79 blazer into a yj ( I have a dana 300 I can use) Or should I stick with the ford hp44 and 9". The 44 would have to be retubed or make a 3 link and keep the radius arms.
I have both sets of axles.
12 bolts are c-clip negative, more expensive to biuld due to not as much aftermarket support. but if you have it not a bad axle. 10 bolt vs a 44 run what you got or which ever will be easier.
