Tacoma747
- Mar 20, 2005
- Winston-Salem
I have 44044's up front, 14" bilsteins, and a D44. I just went outside and did a flex test, dropped the drivers side tire to 12" on the shock, driveshaft had 4" showing, and probably not much left to go.
My problem normally happens going up hills or rocks (upper kodak rock, schoolbus, rock garden at Crawfords), it seems that when the front end is light (weight wise), and I am kind of in a bind, I will try to back up and the driveshaft will pop out. I am thinking that in reverse, since the pinion wraps downwards is where my problem is coming from.
I was thinking about a bar that the stock 83' Yota's had, that went from the axle forward, but I don't have any room for one, and I can't do one going rearward because that would not let the axle flex without binding.
I was thinking a limiting strap, but then I would lose a ton of flex, but I might not have a choice at this point. I am planning on lengthening the driveshaft with some tractor PTO shaft, but won't have it in time to do it before this weekend.
Another idea was to weld a bracket on top of the housing (near pinion) to hook a strap on to keep it from wrapping.
Basically, my driveshaft needs more travel, but where the problem is originating is axle wrap, I can't add any more leafs, because the front is already higher than the rear.
Any ideas?
Thanks a ton...
Any ideas?
Thanks a ton...
