BA10 questions
TODBLDZ
Member
CLOVER,SC
i have an 87 yj with a 258 and a BA10. i grenaded it a few months ago. posted on the WTB for another one. MTNYJ has one but it came out of an 89 cherokee with the 4.0. my question is will it straight bolt to my 258 or not. got this link http://www.novak-adapt.com/knowledge/ba10_5.htm
which says the ba10 will only be foung in the 258 combo. any one have an idea on this? thanks.
its bolt up, but you'll have to re-drill the holes for the x-fer case. yj's clock the case about 10 degrees more upward than xj's. if you ever plan on doin any kind of wheeling, swap a ax-15 in. chris.
thanks for the info. i was afraid of that. a guy at work is having that problem in 4cyl yj. didnt know if i would on the 6cyl. i only busted the bellhousing on the ba10 and i have an ax15 sitting in the shop so just a few more questions:
would the ba10 bellhousings interchange so i could just use my trans?
what needs to be changed/upgraded to use the ax15 in the yj?
Sell it and build the XJ!!! :D
Seriously though, if its just the bell housing thats broken i'm sure you can find one on a bad tranny to swap in.
