Backlit switch panels and wiring solutions from 12Volt Unlimited 15% off!!
12Volt Unlimited
Order a switch panel and one of my new wiring harnesses today and receive 15% off and free shipping on the entire order! This offer is good until the end of the month so act fast!
Switch panels are available with or without backlighting. Backlighting is available in red blue and green. They come with high quality triple sealed waterproof switches, panel mounted circuit breakers and LED indicators.
The new wiring harnesses are designed to be used with one of our switch panels with circuit breakers. They are available in 10, 14, 18, or 22 circuits. Each color coded circuit has 12 feet of 12 guage wire, and are rated for 20 amp each. The 22 pin weatherpak bulkhead connector mounts to your firewall and is easily disconnected by loosening the screw that holds it together. The 10, 14, and 18 circuit harnesses come with connectors to add wires to the 22 pin bulkhead connector if you need to. There is also an optional kit of weatherpak connectors for each accesory (not pictured)
These are a great way to get your wiring job done quick. Mount your panel, mount the bulkhead, and start runnin wires.
Post up for pricing as I have yet to add the harnesses to the website.
Thanks for looking.
Backlighting on
Backlighting off
10 circuit harness
