BigBody79 Well-Known Member Joined Mar 30, 2005 Location Lumberton Nov 2, 2007 #1 i think that i have a bad tire. there is a buldge in the tire right by the rim. you can start to see the inner bead. what causes this? what can i do?
Jeff B Thanos was right Joined Dec 23, 2006 Location Lincolnton N.C. Nov 2, 2007 #2 I don't know, change it
85TrailRunner Member Joined Mar 16, 2007 Location Monroe Nov 2, 2007 #3 More then likely its a broken steel belt inside the tire, I'd change it as soon as possible to avoid a blowout.
rhinoextreme New Member Joined Mar 8, 2006 Location Havelock Nov 2, 2007 #4 re: tire sometimes it can be caused by running a low tire pressure or over heating of the tire. It is usually a cord or belt separation and nothing can be done. You need to replace it before it blowns and you get hurt. thanks ALex
