bigmackloud
- Apr 6, 2005
- Raleigh, NC
Hey,
just thought i'd share the good results. I finally tried the water/antifreeze trick for balancing my 35x14.5 Boggers. I used 8oz, but if i were to do it again i'd probably do 10oz just to be on the safe side. took it out on 540 this afternoon, up to ~70mph, and they ran smooth. very happy.
and we even found an easy way to get the water inside the tire. basically removed the valve from the stem, and let the air out of the tire. then we had a vacumn canister and an air hose. hooked the line from the canister to the valve stem, and actually created a vacumn inside the tire. pinched off the line and disconnected it from the canister, and dropped the line into a bottle with the water/AF. the vacumn inside the tire sucked the water into the tire. that simple! did all four tires in no tire flat.
it's been a productive week working on the CJ. replaced a spring perch, rebuilt my oil pump, got a new radiator, fabbed a coolant overflow tank, replaced the springs in my dizzy for quicker advance, changed the oil, replaced the coil, balanced the tires, and even put on a couple of new stickers! all in preperation for the CJ's maiden voyage to Uwharrie this weekend! we'll see how she holds together!
happy trails,
bigmac
happy trails,
bigmac
