RatLabGuy
- May 18, 2005
- Churchville, MD
so i've got a 33" MT w/ a good sidewall gash. Found a local place that will put a tube in it.
Previously I've been using wheel weights to balance it - with debatable results. Figured it's time to switch to bead/water balancing anyway.
Sooo... the magic question is... can you still do thsi w/ a tubed tire? Would it go inside the tube, or between it and the tire?
Even if I could get them to patch the inside of the wall so it's water tight, will it still wok, or will the tube just keep the water/beads from moving around? Likewise, the inside of the tube is not the same "round" that the tire is, so I'd think that the water wouldn't really end up in the right places to balance at speed?
