Barnes 4wd 3/8" Diff Covers
Barnes 4wd
Etowah NC
All Barnes 4wd Differential Covers are laser cut and bent in a state of the art CNC Press Break. The entire cover is made from 3/8" US Steel and we GUARANTEE THEM FOR LIFE. All covers are fully welded and machined flat and the threaded fill plug is TIG welded in place. These covers are made to withstand the hardest conditions. Like all our products they are made in the USA.
Dana 60 Differential Cover
Dana 35 Differential Cover
Dana 30 Differential Cover
Barnes 4WD GM 14 Bolt High Clearance Shave Cover
The 14 bolt is a great axle. They are cheap, strong, easy to find and cheap to build. However they have always had one down fall, that huge lip on the bottom that get hung one ever thing on the trail. Barnes 4WD has come up with a solution to this issue. Our GM 14 Bolt 3/8” Shave Cover. This cover will give you more than 1 ¼” of ground clearance. Another thing that makes this a great shave cover is that you will not need to have your gears turned or perform a complicated welding or machining process that just adds more cost to your axle build. All that you will need to do is bolt the diff cover to your axle and cut off the extra lip. This can be done with simple tools that you have and you can do it yourself and we GUARANTEETHEM FOR LIFE! Like all of our diff covers they are made from 3/8” plate and machined flat after they are welded to insure that you will have a flat surface to mount to your axle. We do recommend using allen head bolts on our GM 14 Bolt Shave Cover.
Click here for the Barnes 4WD 14 Bolt Diff Cover!
awww.barnes4wd.com_assets_images_Axle_20Accessories_Differenti9db91a445f9761187d5637c9f8214569.jpg
ILL WAIT IT OUT FOR THE 14B COVER. I LIKE HOW YOU STAMP THE CAMPANY NAME IN THEM. WHATS THE COST?
did you ever get around to making some rear diff covers for the FJ80 axle?
Thanks for your business
Give us call if you need we are here on Saturday mornings to pack orders and help you with you Saturday project.
6years wheeling d30 frt in tj 37s lockers took it every where best advise up grad to to 44 60. all said need ring & pin for 99 tj d30 frt need two susp seats for s10 frt cover for d60. brad missed you this trip to harlin took s10 saw johnny up there give me call sherrill thanks :driver::driver:
saw your old buggie new owner
Still waiting on a FJ80 rear cover. Any idea if they will get added to the list?
