Barnes 4WD Bump Stop Pads
Barnes 4wd
Etowah NC
Barnes 4WD Bump Stop Pads​
Barnes 4WD bump stop pads can be used with hydraulic air bump stops or rubber and polyurethane bump stops. The brackets are laser cut and CNC bent from 1/4" steel. They measure 4.5” x 5” and are precut for a 3” axle tube. Each bump stop bad is sold individually. They are made in the U.S. from U.S. Steel!
