Barnes 4WD Heat Treated Chromoly Heims
Barnes 4wd
Etowah NC
Barnes 4wd is proud to introduce our new line of Heat Treated 4130 Chromoly Heims. We have the small 3/8" all the way up to the 1 1/4". These heims are made of the best materials and the heat treating only makes it better. We have nine different sizes so you can find just the right size for your application.
https://www.barnes4wd.com/Heat-Treated-Chromoly-12-20-X-12-Heim-Joint_p_173.html
Chromoly 1/2- 20 X 1/2"Heim
https://www.barnes4wd.com/Heat-Treated-Chromoly-58-18-X-12-Heim-Joint_p_175.html
Chromoly 5/8- 18 X 1/2"Heim
https://www.barnes4wd.com/Heat-Treated-Chromoly-58-18-X-58-Heim-Joint_p_172.html
Chromoly 5/8- 18 X 5/8"Heim
https://www.barnes4wd.com/Heat-Treated-Chromoly-34-16-X-58-Heim-Joint_p_153.html
Chromoly 3/4- 16 X 5/8"Heim
https://www.barnes4wd.com/Heat-Treated-Chromoly-34--16-X-34-Heim-Joint_p_152.html
Chromoly 3/4 - 16 X 3/4" Heim
https://www.barnes4wd.com/Heat-Treated-Chromoly-78-14-X-34-Heim-Joint_p_150.html
Chromoly 7/8- 14 X 3/4" Heim
https://www.barnes4wd.com/Heat-Treated-Chromoly-78-14-X-78-Heim-Joint_p_171.html
Chromoly 7/8- 14 X 7/8" Heim
https://www.barnes4wd.com/Heat-Treated-Chromoly-1-14-12-x-1-Heim-Joint_p_151.html
Chromoly 1 1/4"- 12 X 1" Heim
https://www.barnes4wd.com/Rod-Ends-and-Hardware_c_7.html
We also have all the Jams, Threaded Bungs and Misalignment Spacers.
We have not carried Midwest Control Heims in a long time (every since we introduced our own line of heims).... but we did keep the best prices for Heat treated 4130 heims!
