Barnes 4wd
- Aug 6, 2007
- Etowah NC
Barnes 4WD Jeep JK Lifted Front Track Bar Bracket
This is our Jeep JK Lifted Front Track Bar Bracket, we designed this bracket with the lifted Jeep JK owner in mind, If you have a suspension lift over 2” on your JK the track bar angle has been increased, this can lead to bump steer, affect the vehicle's roll center, and create an array of other problems; this bracket is designed to circumvent all of these issues. Our bracket offers 2 mounting options 1.75” and 3” higher than the stock mounting location, so the angle of your track bar can be corrected and mirror the angle of your drag link after a suspension lift has been installed. It also moves your steering stabilizer up out of harm’s way to the top of the tie rod, for an 1.5” gain in ground clearance! It is compatible with all year model 2 door and 4 door Jeep JK’s, it features the factory 1 5/8” mounting width and the factory size 14mm bolt hole. This part is manufactured in the U.S.A. from our brutally strong ¼” Ultra 100 Steel.
