Barnes 4wd
- Aug 6, 2007
- Etowah NC
Barnes 4WD Sterling Disc Brake Bracket Pair
The Ford Sterling 10.25 has great ground clearance, strong shafts and it’s not too hard to find, but it can still be improved upon. One easy way is to convert to disc brakes. This saves both weight and stopping distance. Our bolt on disc brake brackets make the conversion very easy. The brackets are sold in pairs and you will need to source a pair of 1996 Ford E350 van rear rotors and a set of 1974 GM ¾ ton calipers.
