Barnes 4wd
- Aug 6, 2007
- Etowah NC
All Kits ship with brackets predrilled to the correct bolt hole size and no extra cost!
Three Link Suspension DIY Kit 1 1/4" Chromoly Heims
This is the kit that has all the parts that we are always using in the shop for customers Three links suspensions. This has all the parts that are made to stand up to the abuse that Rock Crawlers and Trail Rigs see and then some. The kit includes.
1 x Axle Link Mount Pair 10 Deg
1 x Frame Link Mount
1 x Adjustable Inner Frame Link Mount Pair 0 Deg
1 x Link Tower
1 x Outside Frame Panhard / Trackbar Mounting Bracket
1 x Offset Axle Panhard Bracket
1 x Chromoly 3/4 - 16 X 3/4" Heim RH
1 x Chromoly 3/4 - 16 X 3/4" Heim LH
2 x High Misalignment Spacer - 3/4" to 5/8" (pair)
1 x 3/4" - 16 Jam Nut RH
1 x 3/4" - 16 Jam Nut LH
1 x Tube Insert (3/4-16) 1" ID Tube RH
1 x Tube Insert (3/4-16) 1" ID Tube LH
3 x Chromoly 1 1/4"- 12 X 1" Heim RH
3 x Chromoly 1 1/4"- 12 X 1" Heim LH
6 x High Misalignment Spacer - 1" to 5/8" (pair)
3 x 1-1/4" - 12 Jam Nut RH
3 x 1-1/4" - 12 Jam Nut LH
3 x Tube Insert (1-1/4-12) 1 1/2" ID Tube RH
3 x Tube Insert (1-1/4-12) 1 1/2" ID Tube LH
1 x Link Tower
