purpleTJchick
- Apr 6, 2005
- Durham
99 TJ. Wrangler, 90K miles
Background: I parked the jeep about 5 months back due to small problems, I cranked it twice while it was parked. I got a new otima yellow battery about a month before and for the past year I have had problems starting it, it does not turn over right away, but it will with 3 seconds. I thought the battery would help it didn't (I knew it wouldn't but I wanted/needed a new one anyways.
5 months later (last sat) I got to crank the Jeep because I'm going to work on it, stick the key in... I see light I go to turn it over, nothing no lights not even going to attempt to crank. We stick a battery charger on, nothing. If we set it to boost/jump nothing happens. I am able to see the air bag light come on for a brief second that is all. I try another charger and the same thing happens, I try to charge it instead and I get lights till I try to crank it.
I got it working by jumping it from another truck, drove around 5 to 10 minutes, parked it let it idle about 45 min, went to it off, then on and nothing, a brief air bag light but that's it. Try charging and the same thing happened from earlier
This is the part I start scratching my head. The next day we are going to jump so we can move it, for shits and giggles jon goes to crank and it fired right up, no problems.
I need input on what could have caused this, I wanted to fix it so it does not act up on me when I'm driving around town or on the trail. - am thinking a starter problem, and someone else said ignition problem. I do not know any help would be nice
Thank ya
Thank ya
