Originally the coolant was okay and not too bad. The system had been overheated by the previous owner (resulted in a cracked head) which prompted me to buy a stroker
Since the install I have drained it (and everything looked quite clean) filled with a half gallon of vinegar, the rest water, ran to temp then drained. I pulled the radiator out and plugged a hose up to all three openings while moving the thing around to get water to pass through all of the fins. Nothing drastic came out of it and the water passing thru was clear and there didn't seem to be any blockage.
I feel as though with the added heat of the stroker that the stock radiator is just barely not efficient enough to keep her cool while sitting. I think my problem will be solved with a 3 core aluminum radiator and maybe a flowkooler high flow pump.
The thermostat is a Gates product so I'm pretty trusting in that it works fine. Like I said, cruising around she sits right about 200-205. Stopped it slowly creeps up. I've sat for 20+ minutes before and it hasn't even made it all the way to the tickmark preceding the danger zone. Of course, I could just still have air in the system that makes its way to the top of the head when idling. I swear I've burped it 4 times now, but will try again tomorrow.
Max A/C wont kick on the fan for some reason. I did some diagnostics on the relay and the relay plugs. When I jump from the power supply for the relay to ground I should be reading 12V correct? I don't think that I'm getting power to it. I know for a fact that the fan works because I jumped it according to lunghd's A/C diagnostics and it kicks right on.
It also doesn't appear to be coming on at 217 either. I pulled literally every fuse there is and checked them and none were popped. Does anyone know where else to look for this stuff?
One thing I have noticed, which may or may not matter, is that my interior fan/blower only works in the High position. Nothing happens anywhere else. I think I did see that the blower had been replaced with a Uni something branded item.
My next step will be to let her get hot, say about 220 to 230 then check the resistance on the temp sensor and see if that is reading the corresponding resistance for 220/230 or if it's still 210ish. If it's still 210ish then it has to just be air making its way to the sender.
