UTfball68
- Jul 18, 2008
- Granite Quarry
So I'm getting my 79 Bronco back to reliable dd/wheeler status. I've had cheapo carpet in it since I bought it from the PO...after hauling parts and absorbing grease, etc...the carpet smells and I want to do away with it.
With 36x14.5" TSLs and 12" cherrybombs, I wouldn't mind cutting down on some noise to have a conversation...so I would like to cut down on sound. I also wouldn't mind keeping the Bronco cooler in the summer and warmer in the winter. So after some reading, I found alot of guys say the following Peel and Seal is just about identical to Dynamat eXtreme:
http://www.lowes.com/pd_154017-81326-PS625_0__?storeNumber=0495&Ntt=peel and seal roofing&UserSearch=peel and seal roofing&selectedLocalStoreBeanArray=[com.lowes.commerce.storelocator.beans.LocatorStoreBean@29512951]&productId=1018733&ipTrail=204.155.99.89&rpp=32
From what I've read, general consensus seems to believe that cuts out 7-11db of cabin noise. And I should only need somewhere between 5-7 rolls depending on how extensive I get with coverage.
Now my question comes here...as I said, I'm trashing the carpet, and am looking for something that I can just spray out. Which naturally leads me to bed liner. Everyone and their brother is telling me it can't be done. First of all, I understand foil doesn't promote the best adhesion, but I don't think it's impossible. Secondly, I'm the kind of guy that will do something when everyone else tells me it can't be. Problem being, I'm stupid...so I need your help.
While digging, I came across this old Jp Magazine article, that doesn't have much detail, but they rolled Herculiner on to Dynamat...unless the foils have different adhesion properties, what's the difference???
http://www.fourwheeler.com/how-to/body-chassis/154-0608-august-2006-jeep-cooling-kits/
I was also thinking about scuffing the foil and laying down a self etching primer and then rolling something on. Or possibly even laying down some fiberglass and then rolling on. So what says you guys???
Also worth noting, general consensus seems to believe cabin noise is reduced by 2-4db with just bed liner. So between the insulation and bed liner, 9-15db reduction sounds pretty good to me. And in some extreme heat, temps were recognized as being about 45* cooler as well.
