uncc civilengineer
- Jun 28, 2006
- Pfafftown, NC
Well...
Damn, this has been a process...
On the way up to Callalantee this past weekend my cousin was following behind me and called me and said it looks like I have a bent wheel. I said ok we'll look at it when we get back.
I swapped out the spare and ran it down the road... still wobbling (sp?) slightly. I put it up on jack stands and have my brother put it in drive and run it while I watched w/ the wheels off. I can see the Passenger Rotor wobble side to side. I'm assuming that's a bent shaft.
That may explain all the noise i'm getting from the rear end and now I've started to already have gear oil leaking (just replaced the bearings/seals).
In any event I guess i'll order new shafts drilled to the pattern I need. How do I properly measure them?
Thanks,
Chris
EDIT: got ahead of myself... Big Bearing Ford 9" (31sp).
Thanks,
Chris
