I'm working on a '93 YJ, MORE stubby shackle reversal, SOA with 2" Rubicon Express springs, Waggy Dana 44 front. I have a rear mounted tie rod. I'm trying to work through some severe death wobble. All the ball joints are new, non-adjustable, the TREs are new "1-ton" Chevys. I don't have shocks installed yet. I can't seem to get the same caster measurement on both sides, the driver's side is 8 degrees, and the passenger's side is 10 degrees. Is there a reason for differing caster other than a bent housing? I'm assuming a bent housing would be the cause of my death wobble. I'm taking my caster measurements from the machined surface of the flat tops with the wheel turned straight. Any help is greatly appreciated...
