nctom
- Dec 9, 2008
- CONCORD NC
This is for you guys that beat the pudding out of your D60's... What has held up the best for you?
Only if you cant get front wheel drive only. Depends 100% on how your vehicle is set up...if you add cutting brakes to the mix you can out maneuver anyone.Imo, spool up front for most of the courses ECORS sets up equals a lot of three point turns. .
As I sit here healing from 4 hernia surgeries (y'all boys don't over do it and end up like this), thinking outside the box.
Why not run a spool in front with pucks, then you can vary per course? Fast and wide open, 1 puck; slow and climby, 2 pucks? Is this even feasible for this type racing?
Spool and one puck you know which one WILL DIG.
I never shift to front only during a race. 4wd all race.so if i understand this right. the fast guys shift the tranfercase to frt. only and steer with the cutting brakes (rear axle only) for the sharpest manuvers? Done at speed then shift back to 4wd and proceed with the hammer down or climb what's now in front of you.
Seems like that would make it pull to one side, and more likely to break an axle. I don't see any advantages to that over an open diff.As I sit here healing from 4 hernia surgeries (y'all boys don't over do it and end up like this), thinking outside the box.
Spool front.
Selectable rear.
Cutting brakes.
Learn to drive that combination and you'll be set up just like the fastest people in this sport.
Order it all from me and I'll tell you how to drive it too.
