fbpd227
- Jan 12, 2007
- Smoky Mts. WNC- Sylva, NC
I have a '93 YJ with 4 inch springs, 2 inch shackles, and 37" IROKS, it has some wrap as it is, but I live with it ( carefully) for now since I am in the process of gathering all my parts together to swap in a HP kingpin 60 front and LP 60 rear ( full width ) and will be going spring over ( but losing the shackles and locating some lower springs to I'm not taller than I am long lol), si I figure i will address all suspension problems when I get to that part ( the swap ). My question is: what are you guys using for axle wrap that seems to work the best, without limiting flex too bad? Also, if any of you could offer links, or pix of what you got, it would be REAL helpful for me! I am not a newbie, but wanting to learn the CORRECT way and SAFE way of building, after having "rigged" a few trucks in the past, with less than desirable results. Thanx guys!
