cumminsdzl
- Mar 20, 2005
- Wake Forest
So i pulled the rear axle off of my truck last night so the diff can be welded. Obviously i had to disconnect the rear brake lines. I have read the topics on bleeding brakes, but i am a complete newby when it comes to actually doing it.
Now that the rear brakes have air in the system, do i still need to bleed the fronts also? Any secrets to making the job easier?
I guess i really need a step by step on how to do it. Thanks for the help, and if this belongs in the newbie section feel free to move it.
Kyle
Kyle
the third member is cruiser though, because weenie 8" ring gears suck
all this crud about axles hanging on seals.... I pull out hundreds of toyota axles a year and everytime i did i replaced the seal like a normal human. If you are gonna go through the trouble to remove your diff, make sure everything else is in order. Seals are cheaper than bearings and brake shoes, and you could even damage them while just removing them from the truck.
