Blinker Fluid and other hard to find automotive products!
dontoe
Taylorsville
Blinker Fluid
larger image
larger image$8.99 Shipping Weight: 0.5 lbs 3 Units in Stock Add to Cart:
Are you blinkers sluggish? Do they make an annoying ticking noise? Do they not flash fast enough? Here's your solution. Little do people know, factory quality blinker fluid should be changed every 150,000 blinks. Our blinker fluid lasts ten times that. KaleCoAuto high quality synthetic blinker fluid meets the highest DOT standards while not being in the least bit DOT legal! KaleCoAuto blinker fluid provides you with thousands of hours of reliable blinking without the wear and tear on the flash-synchro's that the other blinker fluids cause. KaleCoAuto blinker fluid will not lose its viscosity even in the most extreme situations. Why buy that old dino-blinker fluid, when you can get our unique patented synthetic formula? Satisfaction guaranteed!! For use in any car.
O Pipe (Single Exhaust)
larger image
larger image$89.95 Shipping Weight: 10 lbs 7 Units in Stock Add to Cart:
You've heard of the Y pipe.. the X pipe.. the H pipe.. nothing can touch the O pipe!!! It provides 100% back pressure feedback on ALL engines!! Torque increase and kuneutson valve float brings in much lower revs so you don't hurt your motor! Not CARB Legal. Please specify standard or polished finish. Product shown is single input O-Pipe with polished finish.
And especially for Branndon...............
Adjustable Powerband
larger image
larger image$249.95 Shipping Weight: 8 lbs 5 Units in Stock Add to Cart:
Wish you had a little more low end torque? Maybe you want a high revving formula1-esque screamer? KaleCoAuto's Adjustable Powerbands are the perfect solution! The power bands are made from titanium-injected rubber, with high grade 440 fasteners. Six links are included. One band is for horsepower, and the other for torque. You may use more than three links per side, but extreme caution should be taken!
Link to a lot more hilarious chit...............
__________________
