I have lift blocks on my 92 4Runner on the rear axle....which is because of my frenched rear spring hangers. I wanted to relieve the sag in the back for a short time until I could find a better solution. I'm getting axle wrap pretty bad now. I've had the SAS for 8 months. It is sprung over. I have 4:88 gears with a detroit. Andy from CRSU has seen the rear diff buck pretty bad from a take off. Do you think the blocks are causing my axle wrap? I'd rather try and ditch the blocks than buy a traction bar if possible.
Any suggestions or solutions? A traction bar is a little out of my range at the moment. I can provide pictures if necessary.
Thanks.
Jason
Thanks.
Jason
