mts91xj
- May 16, 2012
- Fountain, NC (near greenville)
Went to drive my jeep to a meet and greet Saturday and got insane amounts of white smoke blowing from exhaust and oil literally flowing out the tail pipe! Pulled the valve cover Saturday night and to no ones surprise there was antifreeze pooled up on top of the head
Got the head pulled Sunday, the gasket actually looked like it had no problems, but will be replaced anyways. Valves on 5 of the 6 cylinders were burnt / oily / wet. Will be cleaning the head good this week, scraping gaskets and so forth. Just looking to get advice on if there is anything else i should replace or check while i've got this thing apart already. (will be replacing rings as well, might as well do it while i've got the motor torn down this far.)
The good news is there is no knocking or ticking going on, so i'm fairly certain the bottom end is holding up just fine, no gouges / scratches in the cylinder walls, other than carbon / oil buildup the valves look good.
Got the head pulled Sunday, the gasket actually looked like it had no problems, but will be replaced anyways. Valves on 5 of the 6 cylinders were burnt / oily / wet. Will be cleaning the head good this week, scraping gaskets and so forth. Just looking to get advice on if there is anything else i should replace or check while i've got this thing apart already. (will be replacing rings as well, might as well do it while i've got the motor torn down this far.)The good news is there is no knocking or ticking going on, so i'm fairly certain the bottom end is holding up just fine, no gouges / scratches in the cylinder walls, other than carbon / oil buildup the valves look good.
