Bullardbs
- May 7, 2007
- Thomasville, NC
Found a deal on a boat but it needs bearings in the outboard part of the engine. That being said is that something that will cost a arm and a leg or is it something that can be done with a little work. I work on cars for a living and have done engine swaps head jobs etc so the work dont bother me just wanted to see what was involved and if it would be worth messing with.
) that's about a $300-$400 fix. However, if the gimbal bearing went bad from water, you gotta check out the u-joint for possible failure too. Ok, I'll tell the story. I, I mean someone I know forgot to pull the plug on my, cough, his boat after taking it out of the water. Well, the boat sat for a month or two with the non rain repelling cover on it. the boat esentially sank in the driveway. The water was just about up to the carb when it was realized. The alt was bad, there was water in the hydraulics, the trim pump had to be rebuilt and the gimbal bearing was toast. Everything but the bearing was a diy job.
