BPE’s on a Cherokee
Maybe like an inch, two inches max. Not detrimental for a trail Jeep assuming your shocks were the proper size in the first place. Going to have to figure that out yourself.
You can use the rear sway bar brackets for bpe's from what I've read. Maybe just have to drill up the through hole. It only compresses the shock an additional Inch or so, so as long as you bump stop before the shock bottoms out, you'll be good to go. Either you can use those brackets, or you can make some with some square tube fairly easily by cutting to length, cut one side of the square off to give a U and drill a few holes.
