Hurley
WTFab
- Feb 22, 2008
- Statesville
I am replacing the hard line that runs from the frame-mount to the rear axle flex line on a 1996 ram 1500, and having problems. I have reused the factory 3/8-24 fitting on new ni-copp hard line, using the standard 45deg double-flare. It is leaking past the flare only, and has done so with every attempt that I make. Originally I thought that I had the wrong flare, but I have retrieved an original line end and confirmed its shape.
I've modeled ~5 flares on this particular end, with the latest one looking exactly like the factory flare (as far as concentricity/ect. goes). One thing that I've noticed is that the fitting actually threads deeper into the connecting block than what it originally had, however, when comparing the original flare with the new flare they are basically the same protrusion.
Any advice?
Any advice?
