Shags
Member
- Oct 31, 2007
- Wilmington NC
Hello I own a 87 Suzuki samurai and im having some problems with the brakes. (just purchased)
Ok the problem I was having was having to pump the brakes to get any pedal to stop. and it doesnt leak or use any fluid, So I figured air in the lines because the previous owner said she had a line replaced. Ok so I Bled all 4 corners (or tried) and I have good stiff pedal for about 10 seconds then im back to no pedal.
Front Right and Left Rear brake only bled out a few drops and looked a little rusty. and every time I tried to get more out it still only got a few drops. The front left and right rear shoot a hard stream out.
I have no leaks anywhere im thinking proportioning valve is clogged or a line is clogged cause the truck is so rusty but the lines look good :-/ The break booster itself is fine its holding good pressure.
Could this be something as simple as a master cylinder?
The brakes arnt working good enough for the pads to knock the built up rust off the rotors but you can see the front calipers compressing when you pump the brake.
Any information would be great!! thank you.
