M&M Offroad
- Mar 16, 2006
- mocksville
This bracket incorporates small size and and a vacuum booster to aid in braking issues found on most buggies. The bracket can be adapted to fit to tube or be bolted to a flat horizontal or vertical area. It uses a common Wilwood pedal. Hydro boost means more hydraulic problems. Keep it simple with this setup..Pm me for a price on full setups. The master is an oem size aftermarket polished aluminum. It has outlets on each side for ease of running lines(1inch bore). You can also retro fit any master that has a 3.375 mounting holes to this assembly. Giving you a range of bore sizes. They can be setup for disc front and rear or disc/drum. The vacuum booster is an aftermarket 7" for clearance issues. Overall length is 17.5 inches.
Full package as shown.... $270.00 Plus shipping
336-909-2076
this is one adapted to a vertical flat plate mount.
336-909-2076
PJ
MandMoffroad.com
336-909-2076
336-909-2076
PJ
MandMoffroad.com
