I am trying to sort out the brakes on the bass boat build. So far I have nothing.
What is in place...
CJ vacuum booster. CJ pedal and assembly.
86 e350 master cylinder. This is the second one. bench bleed following the directions and it felt like it built pressure.
all new lines.
Axles are from an early 80's one ton. disc front with new calipers. rear is drum with wheel cylinders replaced.
I had a cutting brake in the picture but I have since by passed it as I thought that is where my problem was. I used a soft line to by pass it.
power bled. getting a steady fluid stream from the bleeders at all wheels.
I have double checked all fittings to make sure there are no leaks. I can't find a leak.
The issue is that I can't get the pedal to build pressure. when the jeep is off and you pump the pedal up it becomes firmer but the pedal still falls to the floor with steady constant pressure.
When the jeep is on and the booster is hooked up the pedal can be pushed to the floor with your finger. It doesn't seem to be building pressure.
I am at a total loss. This is the only thing stopping me from testing it and getting some trail time on it.
Basically I am frustrated with this thing.... and can't figure it out....
What is in place...
all new lines.
