Tommygunn
Active Member
- Aug 18, 2009
- jordan lake, nc
maybe someone can help me out here. I snapped a Yukon axle on my 2000 model TJ. well, with the snow coming in today I'm trying to get it going so I can go play. I went to the junkyard and got a stock axle just to get me by. they say its for my jeep. well I get home and go to slide it in and it won't fit. everything goes in fine but when I go to slide the hub on, I'm about 1.25 inches short of being able to bolt it up with the 3 bolts. I have no idea why this is. I know the axle is in as far as it will go because the flange by the u-joint sets flush with where it should on the axle tube. any ideas?
the axle I pulled out is also shorter from spline to spline then the axle I bought. what gives?
thanks in advance.
thanks in advance.
The inner shaft had twisted threads and the outer was snapped clean off. what happened to the pics?
